Hi all I’ve purchased a HEDS-9100 encoder https://nz.rs-online.com/web/p/motion-control-sensors/7967878 to replace a low res photo interupt I made. There is little information in the tds as to whether I need any additional componentry to make this run reliably. In the data sheet under recommended operating conditions it has a note alongside load capacitance ‘3.3 kohm pull up resistor’. I’m wondering if this should be included in my circuit somewhere? I was also wondering if the n/c pin needs to be tied to anything and also should the a and b outputs be tied to ground? Thanks for any help
Ant
Mod:Added d/s
Ant
Mod:Added d/s
