EMR DETECTED TL-PA9020P KIT INTERNET OVER POWERLINE
5G EMR by any standard of EMR fear is a lot safer than the old 1G analog cell phone equipment.
The RF was safe but carrying the battery would strain your back.
28,636
The effect of the 1G cell phones on drivers brain functioning was quite obvious. Certainly it tended to reduce their ability to focus attention on driving.
28,636
For a technical explanation as to why there MUST be a detectable ellectromagnetic field related to the device, start with the data rate of 2.5 gigahertz. Now understand that the signal is an electrical voltage that is reversing itself at that rate. Communication theory tels us that to send data over a wire there must be enough current flowing in that wire to change the voltage at the far end of the wire. (calculating the exact voltage to provide numbers gets tedious here, so just trust that the current is not zero.
Basic electrical theory tells us that a changing electrical current will produce a changing magnetic field, and the fact is that a magnetic field will pass right thru most materials. That includes most of the materials that the places we live in are built of. BUT if you live in a steel hulled ship or submarine then they will not pass thru them.
That is enough explanation for right now.
