EMG signal Acquisition Circuit
Javeria
Joined Apr 14, 2019
14
hi,
OK . I understand.
First do this test:
Connect the two inputs of the AD620 together and connect them to 0V, the AD620 output voltage should be almost zero volts.
If the output is zero volts, now check the output of the second OPA, it should also be close to zero volts.
Let us know what you measure.
E
Sure and whats about the +VS and -VS should i leave them without supply or provide them too?
ericgibbs
Joined Jan 29, 2010
21,541
hi J,
I am concerned that you do not have sufficient knowledge to build a safe unit that can be attached to a human body.
What subject are you studying at College.?
E
@bertus
Javeria
Joined Apr 14, 2019
14
hi J,
E
@bertus
Sir I've already tested my ckt and attached to my body as well and captured the following signal using INA106. but unfortunately I burn my ic and now its not providing signal using AD620 i am worried if is it
possible that due to burn IC , the other components are also affected because it was attached to the circuit.
and I am studying Electronic Engineering.
