Hi, I want to make a zigbee based home hub (gateway).
I need help choosing the right software and hardware.
The processor should be some ARM based.
The operation system should be FreeBSD, with Apache HTTP Server.
The hub also should have about 1GB SD-RAM memory, 2-3GB NAND flash memory, also USB port and Ethernet port (with external Ethernet controller or SoC), and ZigBee module.
The hub should work as an web server.
The web address will be the IP, when accessed the website should have functions like turn on-of some zigbee device. In other worlds there should be an website that sends command and receives information from the zigbee module. Also need help how the website will communicate with the module, in what language should be programmed.
Thanks,
Thanks,
