uC and Embedded Linux
engr_david_ee
Joined Mar 10, 2023
364
What is the difference between uC Linux and Petalinux and Embedded Linux ? Which one is the most simplest and lighter then others.
uClinux is an old toy OS that got merged in the mainline Linux kernel long ago, Petalinux is a tool suite and Embedded Linux is just a name for types of Linux controlled systems.
engr_david_ee
Joined Mar 10, 2023
364
uClinux still exists ? Can we run on PIC32 Microcontroller ?
I have heard that most Xilinx SoC support Petalinux. Never worked with it.
engr_david_ee
Joined Mar 10, 2023
364
Thanks for reply. Trying to grab the consept.
I guess in PIC Microcontroller FreeRTOS is used commonly.
uCLinux might be for Raspberry pi.
The PIC32 (original) is a MIPS processor (some PIC32 controllers have MMU and VM support for a proper protected mode OS) so it's possible to run (boot a custom Linux kernel) Linux on it and there are several old demo projects that did but running Linux doesn't make a lot of sense for the vast majority of controller based applications.
https://github.com/MicrochipTech/linux-pic32/tree/pic32-4.2.y/arch/mips/pic32
Ya’akov
Joined Jan 27, 2019
10,295
FreeRTOS or its moral equivalent makes some sense—I can't think of a use case for Linux, though.
Ya’akov
Joined Jan 27, 2019
10,295
There are some complex networking and filtering applications like routers, firewalls and such where a 32-bit controller running Linux can leverage the standard networking power of Linux to great advantage.
https://openwrt.org/
https://git.openwrt.org/?p=openwrt/openwrt.git;a=shortlog;h=refs/tags/v24.10.0-rc4
Sure, but why would wouldn't you go with an ARM or other CPU, the MCU's real advantage is in its peripherals, and routing is a bit CPU intensive anyway. I guess there might be a case for it where light routing but battery power is called for... or something like that.
The 32-bit controllers are ARM/MIPS cores in some cases but with the onboard flash, memory and peripherals expected of a controller. They can handle fairly sizable networking loads.
https://openwrt.org/docs/techref/targets/start
Don't underestimate what's possible today with small Linux controller based systems that don't need user-land based programming access.
Ya’akov
Joined Jan 27, 2019
10,295
Don't underestimate what's possible today with small Linux controllers based systems that don't need user-land based programming access.
Well... such an MCU is the other side of the blurry line from the RPi Zero between MCU dev boards and SBCs. But, maybe that's a useful spot to be in from some projects.
I've used PIC32MK controllers (with MIPS cores and hardware FP) to do some pretty heavy double precision math with IMU data.
https://forum.allaboutcircuits.com/...sing-accelerometer-sensor.174107/post-1568515
The power of these types of 32-bit controllers is what makes high efficiency BLDC motor controllers possible but that application is mainly brute power banging hardware with no need for a OS like Linux. Embedded Linux on similar hardware can use that same controller power for complex, secure networking and high throughput (DMA with highly efficient memory access hardware) in a single controller package.
https://ww1.microchip.com/downloads...oductDocuments/ReferenceManuals/60001214A.pdf
