IDE to develop Embedded Linux device driver
mukesh1
Joined Mar 22, 2020
68
Recently, I was studying Linux Embedded Device Driver, due to the lack of knowledge, so I began to wonder if I could write a driver myself to make the firmware run. No matter how hard it is and whether it can achieve my original intention or not, it pays off a lot if I learn how to develop Linux driver.
I would like someone with more experience to suggest device and compiler to develop Embedded Linux device driver
It's not that hard but you need a large amount of background knowledge about the structure of Linux Kernel and OS structures in general to get started from scratch. You don't need a IDE to edit source files but it helps to keep things organized. I've used VI, Netbeans, Eclipse, and just about any IDE that understands the C language syntax.
https://www.oreilly.com/openbook/linuxdrive3/book/
This is an old book that should help with basic concepts but the modern Kernels have a much different structure that's documented here.
https://www.kernel.org/doc/html/latest/
