Eliminate noise
jalil92
Joined Jun 7, 2019
7
I used sbl-1 mixer for decreasing signal frequency from 3.170 MHz to 10 kHz. The generated signal has high noise level. The 3th order butterworth filter was used to eliminate noise and a lot of noise was reduced, but there is still the noise shown in the attached film. How can i eliminate this noise?
Please help me.
Thank you
danadak
Joined Mar 10, 2018
4,057
That looks like AC 50/60 hertz noise ? Is that your main issue ?
Grounding, Hi Z node pickup comes to mind.
Schematic ?
Regards, Dana.
Papabravo
Joined Feb 24, 2006
22,111
Please help me.
Thank you
The short answer is that you can't. You can reduce the noise relative to the "signal", but you cannot eliminate it. BTW, a 3rd order filter is...just a bit short of impressive. Pay attention to suggestions, don't dismiss them out of hand with no evidence.
