eliminate effect of motion on the GSR sensor
Lemon_Foam
Joined Sep 18, 2017
40
GSR sensor is sensor that can measure skin conductance at static condition. If the skin conductance is measure under motion, the measurement take is not accurate.
So, how can i fabricate a GSR sensor with the help of an accelerometer and adhesive filter for eliminate effect of motion when taking measurement of the of skin conductance
BR-549
Joined Sep 22, 2013
4,928
You can't do it. And even if you did.......the GSR measurement would be useless. Even if you held a portion of skin still........the adjoining moving skin would change the GSR.
BUT......if the movement is periodic........you could average the GSR.
