Electronic Circuit Simulation Software help
chavalisurya
Joined Jan 12, 2016
3
Hi guys,
I was given a Task of implementing an electrical circuit in a Software that doesnot have the ability to perform circuit Simulation, at this Moment.
So basically, what i am supposed to do is to write a Piece of code inside the main Software so that it can simulate electronic circuits. I know its a bit tough Task to do. The help that i am looking for is, if some one could explain me or suggest me a book through which i can learn the fundamentals of circuit Simulation Software. All and any suggestions are welcome.
P.S: I dont want to design a whole new SPICE Software, coz i know it takes Ages and also too complex. All i want to learn is to be able to simulate Basic circuits with one or two components rather than complex circuit such as a Trasformer Rectifier Unit.:p
38,746
I don't understand why this simulation code has to be part of the software you have. :confused:
Just use a standard Spice or other similar program to do the circuit simulation.
There's no good reason for you to invest a lot of time and effort to re-invent this (very complex) wheel.
chavalisurya
Joined Jan 12, 2016
3
Yeah, I agree with you crutschow. But what i want to learn is the algorithm behind these Softwares. I know i can perform the circuit Simulation anytime using the available Softwares like LTspice, Tina ti and so on. For me, it would be interesting to know how it is done rather than simply using them.
Alec_t
Joined Sep 17, 2013
15,155
I did something like this in Basic, many moons ago, for a fixed circuit with only a few components. As I recall, it was mainly just a matter of writing a set of equations defining the currents through and voltages across each component, using Ohm's and Lenz's Laws.
chavalisurya
Joined Jan 12, 2016
3
Thats a positive hope Alec_t,
It would be more helpful if you could shed some light on how exactly you were able to do that or some books that i can refer to . Many thanks in advance.
