ok i reading
If you have questions please ask! -- I encourage appropriate questions!ok i reading
Port 1 impedance indeed equals (11-3j)Can we write
(11-3j)
(90+650j)
port 1 and 2?
The form 'conversion' formulae are merely an 'adaptation' of those for compounding resistors:Xport2 (series form)=(650*90^2)/(650^2+90^2)≈12.2271
Rport2 (series form)=(90*650^2)/(90^2+650^2)≈88.307
Please tell the formula ?
i got it.
The port reactances are 'canceled' via compensation (i.e. 'adjustment' of the corresponding network reactors) and hence irrelevantPort 1 impedance indeed equals (11-3j)
However because port 2's impedance is specified in parallel, we must first covert it to series form before we may write it in rectangular format.
So:
Hence:
Port1 Impedance = (11 - 3j)
Port2 Impedance = (88.307+12.2271j)
but in figure there is difference, if we convert // to series we will cut the original to get value in series?
These value are not written.
There is no need to convert it to series equivalent form - it's canceled via adjustment of the network capacitor...Anyway, the // is converted to series than why it is shown in figure // form.
and two extra C L are added how?
Like so:There is no need to convert it to series equivalent form - it's canceled via adjustment of the network capacitor...
Then why we were using this formula?There is no need to convert it to series equivalent form - it's canceled via adjustment of the network capacitor...
Because you wished to write the port impedances in rectangular format:Then why we were using this formula?
Can we write
(11-3j)
(90+650j)
port 1 and 2?
The product 2Pi is the conversion factor of Hertz to radians per second -- hence its application to AC circuitswhy we use 2*3.14(pia)
while calculating impedance??
The circuit should also be changed with it.Because you wished to write the port impedances in rectangular format
