Hi Joe, I am measuring the transistors in circuit, I have not removed any of the components from the pcb.http://www.eagle-audio.com/upgrades.htm
Eagle audio recommends you replace all the electrolytic capacitors, but till you solve the problem, you might as well wait.
Are you measuring those transistors "in circuit" or are you disconnecting them before doing the resistance measurement?
Eagle 7A Revision 2 maybe someone's personal revisions to the amplifier especially with those pen and ink corrections. Unless you check every component listed on the schematic against the circuit, one will never know.
So you are saying to disconnect each transistor and check them individually? Thanks!
