I'm sorry, but i don't understand at all now. I thought that what you have stated is what is true with my circuit already. I thought that the two inputs are practically both the same, give or take a very small amount (The amount given out by the sensor, plus a little from Vos). I'm not getting how i would bias the opamp by 1v by what your saying. Sorry.If you shorted R3, Vos or the voltage (because of not being a perfect OP amp) between the + and - gets amplified.
The current some 2 pA per ppm gets converted to a voltage e.g. (2e-12 Amps) and multiplied by a big number.
Vos has to be small, so it doesn't swamp out the measured value.
