Electricity safety questions
UnnamedUser159
Joined May 3, 2016
501
Hi there.
Before a long time i had some fears about safety and electronic devices - thoughts about someone will be hurt if i dont be carefull enough and so...
I have some questions which answers gonna make me feel good and confident.
Right now the questions are about lcd monitors...
here`s example from today:
https://flic.kr/s/aHskAFJ9pR
i put the board in this black frame. is something missing like some plate?
Part two :
if we watch the boards:
- the right board - there was three holes for screws. i think there was signs like sun(look uploaded picture in the end of post) on the front size.
- on left board - there was 4 holes for inserting screws, but these "suns" are on the back side of the board
Why there is a difference of the sides on the two boards ?
i see one general screw which connects metal part with power bush(port).
And the general question : what are really they for?
About nulling the boards so the both boards and display can work normal and for safety ?
What safety for example ?
Here`s the picture of WWW(please zoom it) : https://flic.kr/p/HCDAB2
Thanks in advance !
Kermit2
Joined Feb 5, 2010
4,159
The "suns" are called star washers. They insure a good metal to copper contact and are to put the chassis ground and power ground together for safety of the user. They are located on top or bottom as required by the location of the copper on the board.
18,162
Your question is very hard to understand. Can you be more specific - one thing at a time - and show a picture of just what you are asking about?
UnnamedUser159
Joined May 3, 2016
501
Hm Hm :)
Do i understand right ? The screws on boards 1 and 2(in monitor case) are for the they to be grounded and then the grounding cable which is connected to third wire is just connected to the chassis to put everything "out"(to the power network,"wall")?
Is there some safety function in this case? The monitor housing(case) of course is plastic.
Nice Day.
30,808
The method of fixing component frames etc to a metallic enclosure with star washers is to achieve something known as equi-potential bonding (to earth), this is more to reduce the chance of ground loops etc, as well as the grounding safety aspect.
With a plastic enclosure this is not easily possible, but the frame should normally be earth grounded.
http://electrical-engineering-portal.com/purpose-of-equipotential-bonding
ian field
Joined Oct 27, 2012
6,536
We're talking about the ones in the middle, right?
The middle one is best for making an earth connection by a bolt through painted or plated chassis.
The internal star on the left is not as good for earthing and is more popular where you don't want to spoil the finish around a fastener.
AFAICR: the earth bolt cannot be in *ANY* way structural - that even goes as far as you can't just bolt the earth tag to the chassis. The bolt goes through the chassis with a fixing nut that serves only that purpose, the external star goes under that nut. Once the earth bolt is so secured; the earth tag is fixed with a nut all of its own - that nut has the split washer and at least one plain washer.
