If I have 2 coils on either side of the galvanometer. And, I will be running a magnetic field around the coils. If one end of each coil is going to the meter, does the other end of the coils need to be connected to each other?
You might get answers if you can supply a picture of your proposed circuit. But as a guess to what your doing, you do need to complete a circuit. And just putting a static, non-moving magnetic field near a coil of wire won't produce any electricity.If I have 2 coils on either side of the galvanometer. And, I will be running a magnetic field around the coils. If one end of each coil is going to the meter, does the other end of the coils need to be connected to each other?
You were told correctly. Things become a bit different with alternating current particularly as the frequency increase, but for what you are doing, a circuit is a mandatory prerequisite.Thanks. That's why I had to ask. I was always told that it needs to be a complete circuit.
"Dead giveaway" for what? If I don't act like an inventor, then you might try to steal my ideas, which might revolutionize the world.Your statement about patents, from your previous thread, is a dead giveaway. If you bothered to read Lancaster, you might realize that by acting like an inventor, you are going about it all wrong.
It still you that would have revolutionized the world for the good hopefully."Dead giveaway" for what? If I don't act like an inventor, then you might try to steal my ideas, which might revolutionize the world.
The principals behind generating electricity have been known for centuries and there are literally teams of engineers devoted to making the slightest improvements in efficiency because there is only so much that can be done with conventional components. There is some merit to not sharing ideas but the chance that you have something groundbreaking despite lacking rudimentary understanding of principal implies you will at best only succeed at reinventing the (most basic) wheel. In my early days of learning electronics I had all kinds of ideas that I've never seen commercially only to realize later they are inefficient and/or economically impractical."Dead giveaway" for what? If I don't act like an inventor, then you might try to steal my ideas, which might revolutionize the world.
