Electrical potential of a point that sits in the origin of the coordinate system
arhzz1
Joined Oct 21, 2020
61
Hello!
Calculate the potential of a point charge Q1 sitting in the coordination origin as a function of the distance r. Assume that for r = ∞
ϕ (r) = 0. What energy do you have to expend to transfer the charge Q2 beetwen any two points (A,B) from the charge Q1.
So what I've tried is this;
ϕ (r) = \[ -\int_0^r E * ds \]
Now here I am missing the E so I've found this formula
\[ E = \frac{1}{4 * \pi * e0} * \frac{Q} {r^2} \]
So I've still got the same issue. What is my r and what is my Q. Should I put Q as e = 1,6?
Does the fact that it is sitting in the spot 0,0 mean anything. Also r is confusing me, r should be the distance,between the two points. Now I havent found anywhere how to calculate this distance.
Some guidance would be great, thanks!
MrAl
Joined Jun 17, 2014
13,690
'r' is a general distance variable.
Charge is measured in Coulombs C. A unit charge therefore is 1C.
1.6e-19 is the charge on one electron, not one unit of charge.
arhzz1
Joined Oct 21, 2020
61
Okay so i cannot put Q as 1,6e-19. My question still remains how do i get the general distnave variable (r)
Papabravo
Joined Feb 24, 2006
22,075
If you are sitting at ∞, you can approach the origin in any direction that you choose. Do you suppose there might be a strategic choice of direction, perhaps along one of the axes? Does the choice affect the result. Does setting Q = constant affect the result?
The integrand is dot product of 2 vectors. A dot product is not the same thing as multiplication. If E and ds are vectors, their dot product is a scaler.
arhzz1
Joined Oct 21, 2020
61
Okay so I've talked to my professor, and I've been looking at the problem completly the wrong way. I was just susposed to show the formulas that are used to calculate Voltage etc.. All it took was a bit of math and integrals. Sorry for the hastle, thank you for the help anyways!
