Electric vaccum solder sucker?
MrSoftware
Joined Oct 29, 2013
2,273
This is the one I have that I like the most, though it's not the most durable:
I have one of those radio shack ones with the red squeeze bulb too, and the idea is good but it doesn't seem to have the same heat capacity as the one I linked above. So it doesn't work well for me for anything that has a lot of copper in it, or for desoldering multiple pins in a row. It just doesn't stay hot. It could be a problem with my specific unit as I haven't tried a different one.
30,813
Everyone seems to be diss'ing the RS one, mine must be a different version as I am certainly not seeing the same results!;)
I have these (which have been mentioned)
and they work, sort of, but I would like to have the power of one of these:
in a small form like these
and could you design it so that it can be built it for $20
Don't know, but I have seen a number of conversions of small aquarium pumps to vacuums https://www.instructables.com/id/Vacuum-Pump-from-Aquarium-Air-Pump/, but they don't specify the pump power and they stress picking up SMT parts more than solder.
This one, https://hackaday.io/project/45998-p1-aquarium-to-vacuum-pump-conversion however, does, but it specified in millibars which I am too tired to figure out from whatever I know about barometric pressure. Also, he is not enthusiastic about the results (again, more appropriate for picking up SMT components than solder), but was optimistic that a more powerful one would work better.
The big pumps, like pictured give cubic feet per min CFM.
spinnaker
Joined Oct 29, 2009
7,830
Yeah and the big ones are expensive. The cheapest at Harbor Freight is $95. They have a version to evacuate AC for around $20 but it looks really bulky.
MisterBill2
Joined Jan 23, 2018
28,322
One source of vacuum pumps that is cheap is in used medical appliances. In many cases even the ones delivering pressure have a pump that has an accessible suction port. I have recovered two like that, one is indeed quite bulky, the other is fairly small. The challenge with solder sucking is that the flow rate needs to be quite large, and the flow must start quickly when wanted. So medium diameter hoses and valves located close to the point of use.
DNA Robotics
Joined Jun 13, 2014
671
A compressor from a refrigerator or small window A/C is free.
Maybe a half gallon in size.
It will pull a vacuum of 30" mercury or better.
I planned on using the small air blower nozzle as a valve so it has time to accumulate vacuum and only used a little bit at a time or the air flow would cool the desoldering tip.
spinnaker
Joined Oct 29, 2009
7,830
Assuming one has an old refrigerator or AC laying around. ;)
MisterBill2
Joined Jan 23, 2018
28,322
In my area they are often available, and don't forget dehumidifiers as a source of compressors, also ice maker machines. Of course there are a lot of places where any sort of free-lance recycling is forbidden by all sorts of laws. Avoid those biggoted areas, they are toxic
I wonder, and am just thinking out loud...you really only need to move the solder a few mm in the liquid state. Would it be possible, in principle, to combine the vacuum pump idea with the solder braid idea? We have probably all used that braid before. Something like sucking the liquid solder into the braid? Again, just thinking out loud.
spinnaker
Joined Oct 29, 2009
7,830
That would solve the need for a tank.
spinnaker
Joined Oct 29, 2009
7,830
Again, I think it would be a lot more simple to just hook it to a household vacuum cleaner. I have one of those canister vacs that is pretty quiet. The only issue I see is you might want it running most of the time but I guess you could have a foot switch to turn it on and off.
