Electric typewriter question
dixieflash
Joined Aug 3, 2019
13
About an electric typewriter - the "Dd" key is inoperative - all others work. Smith-Corona Coronet Super 12.
I know you folks are very savvy. Appreciate any help. Cheers
dixieflash
Joined Aug 3, 2019
13
Okay, found the problem - the D letter leg has come loose at the terminus. I see how to refit it but there is not enough space to get the pin into the hole. Is there a trick to make this work? Thx for help. The videos don't address this.
jpanhalt
Joined Jan 18, 2008
11,087
Yes, a picture would help. If I just imagine the situation, I insert the pin before what it retains, maybe from the other side. Then slide it out just enough to clear what it retains. Tiny forceps help.
dixieflash
Joined Aug 3, 2019
13
I don't see the problem. Be ingenuous
I'm 88 and don't see well, so excuse me. I think you can see the loose connector here - the tiny pin has to go thru the hole in the shiny rounded thing - stick point. I'm struggling. Need two more hands. IMG_3241.jpgIMG_3240.jpg
Mod edit: fix quote - JohnInTX
dl324
Joined Mar 30, 2015
18,524
Those pictures are more helpful. If you just need more hands to do it, make up some jigs to help you.
Find something to attach a wire to that you can use to hold the part illustrated in the first picture up so you can position the pin by the hole.
dixieflash
Joined Aug 3, 2019
13
Thanks, Dennis. I will try that and locking forceps also. I have nephropathy in my fingers and my hands shake. May have to wait on a G.son.
