Too bad the one who bought never realized it was 120VAC
The FET's are gone. I cannot get the FET's from Aliexpress. ....That was a shocker.
They are rated at 250V. The ones I got are 100V. One N and a P channel.
I replaced the FET and get's fried at 120VAC, No wonder.
I replaced them and tried at 85VAC.
I could get around 20 staples and FET's get fried due to heat.
Motor won't load below 80VAC.
So I am thinking of building one. I can get the desired DC.
But before that just wanna know if I can get my hands on a 220VAC circuit, the original one uses a bridge without a cap and a MOSFET pair plus a μC.
I cannot give 220VAC to the original FET's as they are under rated.
And the ones I can get fries at 120VAC.
Not really, but a search using the number gave me this: https://sensing.honeywell.com/SS351AT-omnipolar
Strange enough, the number does not show up on that page.
It could be the sensor as OEM.
It is a hall sensor.
5V and VH2 toggles low when magnet passes over.
Time to design one.
I am having a bit of a trouble figuring out how to switch the N-ch MOSFET.
I will be using 2 IRF840 in paralled. A 500V, 8A one. Vgs is ±20V.
I am gonna use F629 for the job. So the drive will be a 5V coupled with an opto.
Input is 80V DC.
I am sketching some idea how to switch on the MOSET to full ON.
I believe the MOSFET might be damaged at 80V gate voltage, right ?
