electric mic over a long distance
bug13
Joined Feb 13, 2012
2,002
Hi guys
What would the effect on connecting a electric mic over a long distance (15M) to the input of an amplifier, with a shielded cable.
  • Is that going to pick up a lot of noise?
  • If it does, how can I fix it?
  • Will that be any other problems associate with this?
Thanks!
THE_RB
Joined Feb 11, 2008
5,438
Watch the quality of the mic cable. A cable that has high capacitance will reduce the high frequencies. You can measure the cable wiht a capacitance meter if you have one.
Also some cheap cables are noisy and will make crackling sounds when flexed and stood on. You'll have to check that the hard way. :)
bug13
Joined Feb 13, 2012
2,002
How much of capacitance would be considered high?
bug13
Joined Feb 13, 2012
2,002
I assume you mean an electret mic which is considered low impedance. You can go hundreds of feet with it with no problem.
Hi Lestraveled, do you mind explaining why low impedance mic can go hundreds of fleet? So can I assume that a high impedance mic can't go very long?
to3metalcan
Joined Jul 20, 2014
263
The mic + cable start to form a lowpass filter, like so:
Where R is the impedance of the mic and C is the capacitance of the cable. The longer the cable is, the bigger the "plates" of the capacitor become, which means the filter cuts off lower and lower. If the mic impedance is low, this effect is usually negligible, or at least inoffensive for most applications. But if R was already big, it doesn't take that much C to start getting audibly low cutoff frequency!
to3metalcan
Joined Jul 20, 2014
263
Y'know, RB, I know this is true from personal experience, but I don't actually understand why. Care to comment?
THE_RB
Joined Feb 11, 2008
5,438
I can't remember exact values it's been a long time since I worked on pro-audio equipment.
If you google some specs for expensive high quality audio coax the pF/foot spec should be listed (or pF/metre more likely these days). Then cheap cable it won't be listed because they are embrassed.
I remember doing one job for a commercial recording studio where I went back later with the capacitance meter as a favour and measured a heap of coax cables, some were terrible for capacitance. The studio sound engineer knew the bad cables too, from their shitty sound. They were still fine for some tasks.
No idea really. I think it moves the bare braid wires (or conductor wires?)relative to each other, making them touch or scrape each other which makes a noise signal. It is worse in real old beatup cables so they might have more conductor breaks and are more affected by cable movement.
Sensacell
Joined Jun 19, 2012
3,786
I read somewhere that microphonic behavior in cables is caused by triboelectric effects in the insulating materials, they generate minute voltages when flexed or struck.
kubeek
Joined Sep 20, 2005
5,796
That, and also when you have a phantom voltage to supply a condenser mic on the far end, then as you step on it you squish the dielectric so the capacitance changes which induces change in voltage.
alfacliff
Joined Dec 13, 2013
2,458
the low impedance of the electret is because of the fet amplifier in the mic cartrege. low impedance signals have lower voltages, but have higher current than high impedance signals, like from a piezoelectric mic.
bug13
Joined Feb 13, 2012
2,002
Just another question, I measured the resistance of a couple electret mic, it reads ~800ohm and ~1k ohm, it that still consider low impedance? Or did I do it the wrong way?
to3metalcan
Joined Jul 20, 2014
263
Bug, that would be about average impedance for an older dynamic microphone, but it doesn't really apply here: the electret mic has a built-in active FET (that's why electrets require a voltage.) Its impedance is not measurable the normal way. When the transistor is energized and running, the effective output impedance is quite low.
ronv
Joined Nov 12, 2008
3,770
The impedance is determined by the bias (load) resistor. So with long cables you want it low but within spec for your microphone. This will make the nominal output lower, but the high frequency roll-off will be less pronounced. Not all cable is created equal so pick some with low capacitance.
bug13
Joined Feb 13, 2012
2,002
The amp connected to the mic only have 16kHz sample rate, does it mean I only need to worry the max frequency up to 8KHz? Instead of 20KHz normally?
