A while back I got an old 1991 yamaha psr-530 and it was in great condition. Eventually a problem started happening where all of the Ds and Gs stopped working making it pretty much impossible to play. after a while I removed the speakers so that I could use them is something else and when a friend came over and tried it out, BAM it worked fine. Of course, I had to plug it into other speakers with the headphone port. Later, I put the speakers back in to see if it would work. I didn't even plug them into the board I just put them in the case and it stopped working again. This would all be fine considering its working fine until recently the lowest G stopped working.
I disassembled the keyboard again, this time to completely dismantle it to the point to where I could clean the keys. I cleaned the keys and the key button pad things and put it back together. I must have put the pads in the wrong order because this time the lowest G worked but the middle G did not.
