So... I have a gable fan installed in my attic. It is connected to a simple, dial thermostat.
I recently noticed that is was not coming on. I can tell you that the blade spins freely, so the motor doesn't appear to be ceased.
I've taken the following troubleshooting steps:
- Wired the fan directly to power to rule out the thermostat. The fan does not spin.
- Replaced the capacitor with an EXACT match in specs: 10mF +/- 5%, 250V AC. @50/60Hz. The fan does not spin.
- Checked voltage at the power feed: 124 V AC
So I have the correct power and a new cap. The blade spins, but can it still be the motor?
Guidance please.
Thank you in advance.
Guidance please.
