Electric Car Seat Diagram Help
Mikewill53
Joined Sep 16, 2018
I'm hoping someone can help, the electric seats in my car dont work. I've got a wiring diagram that I'm trying to work through. On page 225 of the following PDF it shows the diagram
http://www.lrservice.ru/data/277/RR_SPORT_VIN_147226_OK.pdf
What I've noticed is that VBatt electronic going into the memory module, which I believe is the power to the electronics from the battery doesnt have any power. I'm hoping someone can tell me if its meant to have constant power? If not Im guessing a break somewhere in that connection is causing it.
Thanks for any help
Regards
Mike
panic mode
Joined Oct 10, 2011
5,179
there are two supply circuits:
VBATT POWER - high current, used to supply power to the motors
VBATT ELECTRONICS - low current, only supplying logic
both circuits have positive and negative terminals. poor or missing connection at any of them could cause unit to be non-functional. (yes, don't forget to check negative terminals).
same goes for switchpack. if common is not connected, no button will work. this is why the ground connection on switchpack is redundant.
Mikewill53
Joined Sep 16, 2018
Ok thanks, I'll check all of those things later
