- Joined Jan 23, 2018
- 28,457
OK,Folks!! Here is the connection scheme for the four circuit stereo earphones plus microphone plug: Tip= left channel (usually), ring =Right channel (unless swapped with the left) , THEN comes the first part of the sleeve, just past the ring: THAT is the "common" for both the headphones AND the microphone circuit. Then the final segment of the sleeve, which is the very end,is the microphone hot (signal) connection. NOW on the jack, if it is a three circuit jack only intended for headphones, the "sleeve" portion that is intended to make contact with the common on a TRS, (tip Ring Sleeve) jack may be rather short so as to leave room for the switches intended to disconnect the internal speaker in the package. That sleeve may be too short to contact the "common" sleeve.
Adding that microphone connection should have been forbidden, and none of that garbage ever allowed into the USA!! The four circuit plug should have been a larger diameter so as to not fit three circuit jacks.
Being in a crowd with a bunch of individuals jabbering on their phones, always louder than needed, is a real nuisance, and rather an irritation when I am trying to have a conversation with a person next to me.
