Electret Condenser ID
Windburn
Joined May 20, 2017
7
I'm trying to replace a potentially faulty electret condenser microphone in a baby monitor. What does the number 2 mean on the component?
Is there any other way I can determine the standard operating voltage and impedance of the part? When I measure the impedance I get about 0.9 kOhm, but if the part is bad, then that value is incorrect.
Thanks.
AlbertHall
Joined Jun 4, 2014
12,663
If you're just trying to replace it, measure the voltage across where it was connected then connect a new one so the polarity is correct. I believe they are fairly interchangeable.
