Efficient Power Supply
chrisw1990
Joined Oct 22, 2011
551
Hi All,
my input voltage varies from around 12-20V, maybe dipping below 12V too sometimes.
I require 12V 50mA power supply, an efficient one, my current schematic uses a step down, which then drives a step up (as well as other circuitry)
how can i do this more efficiently?
Regards
wmodavis
Joined Oct 23, 2010
739
A schematic would be helpful.
... "uses a step down, which then drives a step up"...
A step down transformer then a step up transformer???
That in itself is inefficient. If that is not what you mean you need to be more precise in your explanation. Or like I said a schematic would help. Can't read your mind though.
Wendy
Joined Mar 24, 2008
23,429
While it is technically possible to not use a transformer it is very unsafe to do so. For this reason a transformer must be used for a project done at AAC.
Transformers generally are very efficient parts, their conversion efficiencies can exceed 95%, though it is not a given.
A switching mode power supply (SMPS) is also very efficient, or can be. They tend to be a bit more noisy than their linear counterparts. The linear versions are much quieter, but make a lot more heat. Everything is a trade off.
Submission: Power Supply Circuits
I'm working on an article for the AAC book that is very much a work in progress. It may answer a few questions though.
joeyd999
Joined Jun 6, 2011
5,287
Hi All,
Regards
You want a SEPIC converter. Google it.
bountyhunter
Joined Sep 7, 2009
2,512
Hi All,
Regards
If the input is both above and below the regulated output, I beieve you need to use a buck-boost switcher.
http://en.wikipedia.org/wiki/Buck%E2%80%93boost_converter
http://www.intersil.com/engineeringtools/tools/buckandboostcircuit.pdf
