Efficient Method to Control Cooling of Peltier Module
Vish Ram
Joined Apr 25, 2017
21
Hi Experts,
What is the cheapest/most efficient method to control cooling of Peltier module (TEC 12706) via remote control.
Thanks in Advance
Ashish
Ya’akov
Joined Jan 27, 2019
10,328
Could you explain what the context of this is? What will the device be cooling, why does it need remote control?
Describe the problem to which you expect this to be solution. This way we won't go around in circles extracting little bits of important information until we know what we are trying to help with.
[EDIT: just formatting]
35,245
Hi Experts,
Thanks in Advance
Ashish
You have identified two separate needs.
The first one is that of a temperature controller. There are numerous low cost devices offered for sale on the web.
The second one (remote control) is more problematic. By remote I will assume you mean via the internet using a smart phone or computer. This involves IOT, a smart phone app or a service provider. There are off-the-shelf solutions available on the web.
Vish Ram
Joined Apr 25, 2017
21
I divide question into 2 parts,
1. How to control temperature for Peltier Cooling, it's via simply switching On-Off power supply or some other way, I mean how to control temperature of Peltier
2. If I've to use in some movable beer fridge (small 1), so for that purpose remote controlling is required
Kindly support
Regards
Ashish
35,245
Kindly support
Regards
Ashish
You have posted again but you have not added any new information.
1) You need to control temperature of the beer fridge, not the Peltier.
Measure the temperature. Turn off the power supply when the temperature drops below a set temperature. Turn on the power supply when the temperature is above a set temperature.
2) What do you mean by “remote control”?
You can control the beer fridge remotely with a long piece of paired cable and an on/off switch.
