Effects bypass footswitch with LED
BassmanL42
Joined Jan 5, 2009
1
I have two audio effects units that have foot switch
operated bypass functions, which use momentary
switches. I want to add an led indicator to show when the effect
is on or off. Can anyone suggest possible solution how to
configure this. (would be all so :confused:easy if switches were latching!)
bertus
Joined Apr 5, 2008
23,001
Do you have the schematics of those effect boxes?
If so we can have a look how to implement the leds.
Greetings,
italo
Joined Nov 20, 2005
205
I don't see any problems if you can find out what voltage and current is flowing trough those switches. Adding a led it would be mostly mechanical. what you need to lite a LED is 1.8v for red and 10-20ma.
found out first what you have then I will help.
