It's for a 1992 ch mack truck. pops the main power fuse as soon as it installedWhat is the year and model your ecu is from? Shorts on 12V rail are usually easy to repair.
1992 Mach ch613 mack engine. Pops main power feed fuse as soon as its installedIs this an Automotive ECM?
Or for what equipment?
If you open it you will likely find a few large capacitors that have gone bad and leaked out detreating the top layer of pcb.
Probably not an easy repair for a beginner. If your in the states and want to send it out for service let me know. I will send you my company info.
Why do people pass judgment on someone you know not if im a beginner or a well qualified tech. Just cause I ask for a diagram. I open many of ecm in my time this has 7 main power feeds and 4 key feeds with 3 auxiliary power feeds. I gave it a quick look over I see no bad burnt spot or blown capacitors. I was under the assumption this form was about learning and helping people with each other's knowledge. But I see it's more about judgments and pushing your bessness narrative.
I would have gladly offered as much help as you asked for if given proper information. I even run a YouTube channel where I freely post video's of my repairs so your barking up the wrong tree thinking I'm just "pushing" my business. You had provided nothing however so I could not offer anything except a starting point or a external solution. I don't care if you are a beginner or an electrical engineer. I would have given you the same reply based off the information in front of me.EHYDE said:Why do people pass judgment on someone you know not if im a beginner or a well qualified tech. Just cause I ask for a diagram. I open many of ecm in my time this has 7 main power feeds and 4 key feeds with 3 auxiliary power feeds. I gave it a quick look over I see no bad burnt spot or blown capacitors. I was under the assumption this form was about learning and helping people with each other's knowledge. But I see it's more about judgments and pushing your bessness narrative.
Whats your youtube? Im trying to get in contact but this forum wont let me send a message. Email me if you can [snip]I would have gladly offered as much help as you asked for if given proper information. I even run a YouTube channel where I freely post video's of my repairs so your barking up the wrong tree thinking I'm just "pushing" my business. You had provided nothing however so I could not offer anything except a starting point or a external solution. I don't care if you are a beginner or an electrical engineer. I would have given you the same reply based off the information in front of me.
If you only want your original questioned answered:
"How can I find the PCB layout or the functional scamatic of the board"
You cant. There are no schematics that will be released for the internal circuits of your ecu. You will have to pull out a meter and make it yourself. There are VERY FEW schematics that get out for these type of modules. I do this for a living and have maybe 3 not made by me. Its not really needed though. A short on the main feed is not hard to locate if you know basic electronics. Especially in something that old. The only problems with that one will be getting replacement components if its damaged beyond basic passives and diodes.
