Earth Resistance Measurement Ckt
Priyanshu Pandey
Joined Aug 2, 2018
9
Hi
I have to measure the Earth resistance and it will be sense by microcontroller and if it will be too high power have to be shut down . I have Line Neutral and Earth . What can be the smallest ckt to measure the Earth resistance?
Ylee5763
Joined Sep 23, 2015
27
if it is relative measurement, you will need
1. a microcontroller can do high resolution ADC (16 bit or above)
2. two 1k ohm 0.1% resistors: each is in series with ADC pin for measuring neutral or earth impedance.
kubeek
Joined Sep 20, 2005
5,796
That sounds oddly specific. Just those three parts and nothing else?
rsjsouza
Joined Apr 21, 2014
430
As others have said, there is a lot to consider when performing this measurement. If you google for the term "earth/ground measurement guide" you will find several useful guides from Fluke, Chauvin Arnoux, etc that will certainly help you narrow your problem proposition.
35,198
If TS wants to measure soil conductivity I can beat that with one microcontroller and one capacitor.
I don't think TS is measuring soil conductivity. TS wants to measure resistance between mains NEUTRAL and EARTH BOND.
What happens if what you think is NEUTRAL is not NEUTRAL and is in fact LINE?
