Dual active bridge ZVS Ltspice Simulation
ernd59
Joined Aug 26, 2015
Hallo :)
im trying to do a Simulation of a Singel phase shifted dual active bridge
Uin =800v
Uout=800v
i used SW Switches but i added CDS and a diode do they will act like a MOSFET, the voltage waveform looks as expected but the current waveform doesn't make , i was expecting ZVS (d =Uout/Uin= 1 and 0.5*Lleeak*i^2>>> 4*0*5Cds*Uds^2 ) , but the Id Current have a strange Trapezoid form and does not go on when Uds = 0 :/
i tried to implement dead time (1us) (6us on and 7u off) but it does not have any effect on the Sw switches
any ideas on what i missed would be really helpful
Fethi
Alec_t
Joined Sep 17, 2013
15,158
You have given the switches a negative hysteresis parameter value, so they will transition gradually, not instantly, between the on and off states. That will result in sloping rise/fall edges to the current waveforms. Also, the bridges are driving inductive loads, so current takes time to ramp up and down in the loads.
Alec_t
Joined Sep 17, 2013
15,158
Zero volts where?
TryVh=0 in all the switch models. BTW, since the parameters are the same in all the switch models, why not simplify things by using just one model? Generally, the simpler the simulation the faster it runs.
ernd59
Joined Aug 26, 2015
Zero volts where?
zero voltage switching i mean, when Vswitch = 0, the switch starts conducting current
pouya jj
Joined May 28, 2018
Hallo :)
Uin =800v
Uout=800v
Fethi
pouya jj
Joined May 28, 2018
hi, that maybe maked be by difrent of voltage flow and current flow in your LC tank ,when voltage is zero ,the current on the switch was not 0 and ...you can use small capacitor bitwen D and S of mosfet .
