dsp based project
Varsha
Joined Nov 17, 2008
14
can someone suggest a dsp based project that can be done in the undergraduate level...how do u implement audio spectrum analyser.
Thank you
Varsha
22,111
An LVDT is a transformer that is excited with a sinewave. Mechanical motion affects the coupling of the signal on the primary onto the secondary. It can be used to measure distances on the order of nanometers. This precision is commonly required on grinding machines.
leftyretro
Joined Nov 25, 2008
395
Good idea about suggesting a LVDT, it's a nice application that gives good visual feedback on what is being accomplished by the DSP processing.
We used long LVDT to measure travel on a linear actuator with a 12" stroke. It is amazing how accurate they can be. You excite the LVDT via it's primary winding with an AC voltage and by reading the phase and amplitude of the two secondary windings you can determine absolute position with very good precision. That would be a good application of DSP capabilities if you can find an affordable LVDT to play with.
Here is an example of one on E-bay:
http://cgi.ebay.com/Schaevitz-Linea...ryZ67003QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
And it's data sheet:
http://www.cdiweb.com/datasheets/schaevitz/HR-Series.pdf
Good luck
Lefty
