Dry run protection for DC Solar Pump sourcing water from a borehole
bk268
Joined Apr 19, 2017
6
We are installing solar power irrigation systems for smallholding farmers in Rural Ghana,
We have 12V DC 0.18kW (max 20A) pumps, there only power source will be a voltage varying from 15-20V coming from solar panels.
The boreholes are narrow, therefore is not much room for a float switch,
The max flow is 20 Litres per minute but more typical flows would be 5-10 liters a minute
Can anyone advise on flow or pressure switch solutions (I have done a google but I don't have experience in this area and am not confident myself)
Ideally, there would be no second power source or battery needed, and the solution should be as low-cost as possible. something under £20 per unit for 20 units would be ideal.
(It's a charity project replicating 20 units - so cost is important)
let me know if i missed out any key info
Sensacell
Joined Jun 19, 2012
3,787
If the power comes directly from the solar panels, I would worry that the pump might not start correctly as the sun comes up.
It might just sit there getting hot as the voltage slowly rises - until it dies.
An under-voltage lockout would fix this. (but maybe your pump is brushless?)
A rotary vane flow sensor could detect the flow of water, with a bit of logic that starts the pump, waits a period for flow, then times-out for a longer period If the flow doesn't start in a few seconds.
If the flow fails, it waits an hour and tries again?
LowQCab
Joined Nov 6, 2012
5,101
~$20.oo is the buga-boo.
You need a "Vacuum-Switch", ( Connected to the Inlet of the Pump ),
and a "Delay-Off" Timer, to prevent "Short-Cycling",
a "Low-Voltage-Lock-Out" Module with built-in hysteresis, also to prevent "Short-Cycling",
and a Push-Button-Switch, ( rated IP-65 for Water ), for Manual-Priming of the Pump,
and a Mechanical-Relay, which can handle the ~20-Amps @ ~12-Volts DC,
( a "Bosch-Style", Automotive "Cube-Relay" would probably work just fine ).
And while you're at it .....
a Thermostatic-Over-Heat-Switch would be a valuable addition.
( There is, of course, a slim-chance that the Motor has one built-in to it from the factory )
The Timer-Module, LVLO-Module, Relay, and Switch, must be mounted in a Sealed-Aluminum-Box.
It would be advantageous to also mount the Vacuum-Switch inside the Box if possible,
and then run only a Rubber-Hose to the Pump-Inlet.
This will easily blow your budget.
Some Training given to a few trusted workers may be the best overall solution.
bk268
Joined Apr 19, 2017
6
bk268
Joined Apr 19, 2017
6
thanks for your suggestions,
We are very keen to get some sort of protection, it's a self-priming pump so that's not an issue, what sort of cost do you think that would come at? could those components run dirrectly of solar or would a PWM power supply be needed?
And why a vacuum switch rather than a pressure or flow sensor?
thanks again
LowQCab
Joined Nov 6, 2012
5,101
No, PWM-Controls would not be advantageous.
You evidently don't need "Under-Voltage-Protection".
But, ( I'm guessing ), the Pump-Seals may fail if run dry,
and this is what You are trying to avoid.
If the Pump is sometimes run with just an open-ended-Pipe,
then little, or no, Pressure will be generated.
This would make a Pressure-Switch fail to operate.
Flow-"Sensors" generally have moving parts that wear from
pumping Sand or other debris, and are subject to clogging,
and will require an Electronic interfacing Circuit.
There are also Flow-"Switches" which would be far more practical,
but both require substantial Plumbing modifications to install.
A Vacuum, at the Pump-Inlet, will always be present when the Pump is moving Water.
A Vacuum-Switch is generally not affected by wear, or clogging situations,
but, depending on the design,
may not tolerate severe Weather, or operating under-water.
However, there are designs that are pretty-much bullet-proof, and very simple,
which means less chance of failure.
A Vacuum-Switch only requires a small hole to be drilled into the Inlet-Pipe
for a Brass rubber-hose-barb-fitting.
The only skill needed is for Tapping the Threads for the Fitting,
and in Plastic-Pipe this is very easy.
There is a possibility that there is already an
existing 1/4"-NPT "Gauge-Port" on the Inlet of the Pump.
This would allow mounting the Vacuum-Switch in a Sealed-Aluminum-Box for protection,
instead of being exposed to certain death in the Elements.
Vacuum-Switch .......... ~$5.oo each
https://www.alibaba.com/product-det...t_catalog.normal_offer.d_title.4f527844cGDMTi
Talk to some of the Chinese manufacturers about buying 100+ Switches so you'll have replacement spares,
otherwise you'll be dealing with standard Industrial/Commercial Manufactures that
will want ~$50.oo to ~$100.oo per-each-part.
The only other parts would be an Automotive-Relay, ( ~$6.oo each, available at all Auto-Parts Stores ),
a weather-proof-Push-Button, ( IP-65 rated for Water ), ( ~$7.oo each ),
https://www.digikey.com/en/products/detail/e-switch/PV2H640NN/3777995
a short piece of Rubber-Hose, ~$1.oo,
and a "sealable" Aluminum-Box .......... ( ~$27.oo )
https://www.digikey.com/en/products/detail/bud-industries/CN-6708/1219193
( a more appropriately sized Box can be selected after the other parts have been decided upon ),
no matter what scheme You decide on,
if it's not in a sealed-Box, it's gauranteed to fail in the Elements.
This project still comes out to way more than ~$20.oo, no matter how You do it.
Just a protective-Box puts You over-budget.
Picbuster
Joined Dec 2, 2013
1,062
The maximum dept of your water source inlet should be =<9meter below surface (10 meter approx is absolute vacuum. Hence no pumping possible form surface)
All other information is already given in previous conversation.
Picbuster
