drop in 5v dc
Roque
Joined Sep 16, 2014
158
hello people....got a 5v regulator (7805) input pin 8v....output is 5v without load....once i connect load input then drops to 5.3v and output to 3.9 ....could the regulator be faulty? or leaky caps ..any ideas would be much appreciated thank you..cheers
#12
This seems obvious, but the local capacitors are necessary to prevent oscillation. Leaving those out always results in unexplainable output voltages.
and specify the exact part number you have. They all require different local capacitor sizes.
Roque
Joined Sep 16, 2014
158
Hi AAA....its seems to be a pretty straight forward circuit all it drives is an prom IC and two 7 segment displays...
Roque
Joined Sep 16, 2014
158
will try the caps tomorrow..probably also mite put in a new 7805...will share the results with you guy....thanks for your input....cheers
38,506
If the input drops to 5.3V then the input supply voltage is apparently being current limited. What is supplying the 8V?
Roque
Joined Sep 16, 2014
158
hello everyone...the problem i had with 5v droping was finally fixed...i had a series bulb connected to the mains of the mixer ...guessing that was the reason the moment i plugged the equipment directly into mains it all came good....was the current insufficient ??
