Drive Solenoid Valve Using IR2111
sghioto
Joined Dec 31, 2017
8,756
If you went with your first solution (4n35) couldn't it drive the solenoid directly with no 2N7000?
It might but it seems from my understanding of the data it would require more LED current then the 18 ma collector current required.
Would not be efficient?
strantor
Joined Oct 3, 2010
6,875
I am not sure but I think you are correct. 50mA to turn it on? That doesn't seem right, but that's what the datasheet seems to say.
Yeah, so maybe not the 4n35, but I'm sure there is an opto that can drive the solenoid directly.
MaxHeadRoom
Joined Jul 18, 2013
30,839
Where does the 50ma come from? How is that possible with a DC coil?
Don't see anything in the data sheet ? According to the wattage quoted.
strantor
Joined Oct 3, 2010
6,875
Well initially this is the number I was talking about:
But I overlooked that it is the ABSOLUTE MAXIMUM forward current. I do not see anywhere that the datasheet says the minimum required current to switch the output. But in other places, test conditions state 10mA forward current,
so maybe that implies a good value?
But then there's this:
Which, if I'm reading that correctly, does seem to indicate you would need 30-50mA through the LED in order to pass 18mA through the other side.
BobTPH
Joined Jun 5, 2013
11,661
OP seems to insist he needs Isolation??
The 2111 high side driver is isolated from the logic and low side. Check the block diagram in the data sheet.
You could power the logic with one supply and use a second isolated supply with ground at Vs 24V to Vb and output at Ho.
