Using a comparator to drive a 24V solenoid valve.
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
I'm getting from a Hall Effect magnetic sensor a variable voltage between 0.8 and 3V. When the voltage is around 0.8-0.9V, I want to activate a solenoid valve. If the voltage goes more than 1V, the valve should be off. So I thought of an inverting comparator like shown below. For the voltage threshold, I will put a precision pot to carefully adjust it to let's say 1V. The valve is 24V, and less than 1A. I don't have the exact current rating now. My question is: Is this the circuit idea yo would choose for this application? I mean, is there a better way? I'm actually looking for a fast prototype. No worth spending much time on this. So this is the basic idea I came up.
Reloadron
Joined Jan 15, 2015
7,947
I would divide the voltage down accurately and think about a window comparator with hysteresis circuit. This allows you a window of operation and hysteresis so when right at a limit your solenoid is not banging away. Keep in mind comparators like the LM339 are open collector out. Anyway based on your description I would think about using two comparators in a window configuration. Your solenoid will only be on when your signal is in the window.
Ron
dendad
Joined Feb 20, 2016
4,641
You will need a pullup resistor on the gate as the 393 is open collector as mentioned above. And maybe a zener or resistor to gnd from the gate as 24V is too high for the gate voltage. The gate voltage problem will go away when you run the circuit on 12V. And a 12V reg will give you a more stable voltage reference.
Adding hysteresis to the comparator will be a good idea too. Have a search for that.
And I think the 1n4148 diode is too small for the coil. Go for a larger current.
