Drain holes for planters...
Externet
Joined Nov 29, 2005
2,656
Hi.
Installed 5/16" i.d. tubes in the planters as in post #14 instead of those 1/8" narrow green ones. At the beginning got blocked by dirt above their level. After clearing repeatedly, seem to drain fine. No flooding.
Some contraption idea needs to be implemented to ensure the drain tubes will stay unclogged and the phreatic level does not rise, to obtain both the 'draining soil' so often sought-after in gardening and a lasting wet reserve below. In other words, the 'draining soil' to drain into a ~4" depth below. I think :rolleyes:
Perhaps reversing wicking ? A wick reaching above the surface inside the drain tubes for draining. Slower, but the tubes would not clog. Hey! Much larger drain tubes diameter with wick inside... :rolleyes:
Externet
Joined Nov 29, 2005
2,656
The global warming hit today In brutal heat, the artichoke plants died today, the tomatoes got dry leaves, and they have drip irrigation 24/7. Bell peppers suffering. Lettuces moved to shade. Not good. :( The planters with the internal drain subject of this thread destroyed by marmots.
It's been over 100F for several days while I was gone. The 5gal drip bucket gets empty quick under those conditions so I called the older child to check the house, top off the bucket and wet the planters. My water monitoring system keeps track using a remote 'cloud' connection to Home Assistant. That BLUMAT watering system seems to working well with large planters. The small planters are seeing heat stress and dry leaves using the same system for watering. https://www.blumat.com/en/tropf/das-tropf-blumat-system/vorteile
Water Sensor
Large planter soil.
May 11
July 11
Externet
Joined Nov 29, 2005
2,656
Hi.
Playing with 2 litre PET bottles. The bottoms are bottom cut cylinder sections, just holding water. The top half is a second cut bottle, with lettuces in soil getting moisture with a piece of old towel as wick from the bottom. So far, a successful way ! :rolleyes:
Also on image: 3 pomegranates begging for transplant, culantro, and junipers.
Ya’akov
Joined Jan 27, 2019
10,274
You might want to check out sub-irrigated planters. There are a variety of designs and they are much more immune to high temperatures and dry conditions than other options. The link is to Wikipedia but there are a lot of sources online for various practical implementations.
Externet
Joined Nov 29, 2005
2,656
About 300 on the tree...
Before the squirrels get to them...
About a sack of pears given to the neighbors. So far, 2 gallons of puree, frozen until the next summer. But not everything went well. Zero artichokes, Marmot took care of watermelons and corn, few bell peppers, just a dozen of plums, insects got the peaches first. Not many tomatoes this year. :(
djsfantasi
Joined Apr 11, 2010
9,237
My daughter has a company that provides custom painted pots. She sells a couple novelty pots. She sells this design (which Dad just had to purchase). See attachment.
