Dpdt relay circuit
Angela.ca
Joined Oct 27, 2016
I want to use a dpdt relay to switch between two power supplies for a load and found a reference in an old book. Can anyone explain the connections of x and x_bar, I understand A+B would be power supply 1, and C+D would be power supply 2. Have I got that right? Are the x and x_bar the connections similar to the coil connections in an ic relay? Also, to modify this to a dpst, I just leave cr4 and cr8 unattached? I think I still need Q2 and Q4, or is there a way to get rid of other components?
Thanks for all inputs!
38,643
That circuit will only work for very specific conditions of voltage and current.
What are the maximum currents and voltages involved?
Can you use a mechanical for this or do you want it to be solid-state?
Do the power supplies share a common ground?
Angela.ca
Joined Oct 27, 2016
Hi crutschow,
The supplies are both within a few hundred mV of 5V and carrying between 1.5-2A, I just need them to come from different sources, same ground. Solid state ic's are rare in spdt, dpdt able to carry this much current, and mechanicals are too large. I'd like to understand this circuit to see how small I can get it.
Thanks!
38,643
The simplest way to switch between the two supplies is likely using a P-MOSFET for each voltage.
Will the switch have to block in both directions, i.e. will one supply ever be significantly different in voltage from the other?
What are the two supplies and why do you want to switch between them?
