Hi.
Two identical television tuners next to each other feed different programming to one television, on ports HDMI 1 and HDMI 2 .
As the tuners are identical, only one remote is needed/used. With both tuners on, both respond to the remote simoultaneously.
Enabling a HDMI port allows receiving the wanted tuner signal, but the remote acts also on the other sending it off the previously selected channel.
Any clever way you may come up with, to select/choose which one of the tuners should obey, and the other to ignore the commands ?
