double flash alternating flasher using 555
gadget25
Joined Mar 6, 2010
6
Hi Guys,
Is it possible to make the red LED flash 2 times then stop, then make blue LED flash 2 times just using a 555 timer? Diagram will be much appreciated :)
gadget25
Joined Mar 6, 2010
6
Hello bertus,
Now I have a question regarding the link you posted, it is shown on the diagrams that I have to use transistor and diodes, but it is not specified what type of transistor or diode I should use. It is not specified does this means that I can choose what type of transistor or diode I want? I would really appreciate it if you could shed me some light :D
bertus
Joined Apr 5, 2008
22,996
In the first picture of the post it says:
CR = 1N4454 , 1N 914 or equivalent.
Q = 2N222 or equivalent.
The same components are used in the other schematics.
Perhaps Bill will verify this.
Greetings,
Wendy
Joined Mar 24, 2008
23,810
I had a similar request for a virtually identical circuit, which I did. I'll hunt it down and post the link, but I'm about to step out the door.
It can be done, and is fairly easy. It took 3 555s, one to select which 555 flasher was lighting up, and the other two to flash their respective LEDs.
gadget25
Joined Mar 6, 2010
6
Something is bugging me, what you just said is what was going in my head, 2 555 timers for the blinking for each set of LED's and the third 555 timer is used to pick which one of the 2 555 timers will run.
Is this possible? :) Anyhow I will try to make this work, if not I will go for your circuit the 3.1 version police flasher. :)
Many Thanks and best regards
SgtWookie
Joined Jul 17, 2007
22,230
Sure, but you would replace the one 555 with a couple resistors and a transistor to act as a logical inverter.
See U2A? That's just being used as an inverter.
So, instead of using two 556 timers, you would use one 555, one 556, and a transistor with a couple more resistors.
Wendy
Joined Mar 24, 2008
23,810
And wind up with more parts.
The original article I referred to wound up gravitating to the original suggestion, a 555 and 4017.
You could also use multivibrators and use 7 transistors. :D
There really is a huge number of ways to do this.
SgtWookie
Joined Jul 17, 2007
22,230
Yep, there's lots of ways to do things; the possibilities are endless. ;)
Speaking of keeping parts count down, I just had another look a bit ago at the thread of yours that Bertus linked to... I trimmed 72 parts from one of your schematics replacing them with 3, and it still does the same thing. ;)
Original:
Modification:
Wendy
Joined Mar 24, 2008
23,810
There is a problem with the idea though, it assumes all the diodes (quantity and colors) are the same. We have enough trouble getting people new to electronics used to the idea that a resistor is required (What if I regulate voltage, or I want to get the parts count down).
The idea was persued somewhat with the current regulator earlier in the article.
