Double BTS7960 43A H-Bridge suitable for peltier heat and cool control?
Kumar san
Joined Jan 5, 2023
16
Hi sir, I am trying to find a suitable solution for heating and cooling of a special part of my circuit. For that, I have chosen a Peltier element and would like to use an Double BTS7960 43A H-Bridge motor driver module with a PWM Control. This H bridge module suitable for the regulation of the Peltier element polarity changes?
The Peltier technology
Heating and cooling in a single system: If a voltage is placed across a Peltier element, one side is cooled and the opposite side simultaneously heats up. Simply by reversing the polarity of the supply voltage, the hot and cold sides of the Peltier element can be swapped.
peltier volt: 12v to 18v
peltier load current: 15Amps
I’ve attached the datasheet of this BTS7960 43A H-Bridge module.
Kind Regards,
Kumar
