Don't Understand Amplifier Circuit Results
elec_dude
Joined Mar 31, 2017
20
I have now built the circuit according to "crutschow" and replaced the two 1 ohm
resistors with 10 ohm resistors. Transistors are now running cold. The current draw
for the circuit has stabilized at 13.2mA and the voltages are as follows:
Q1 Collector 11.93 V
Q1 Base 8.36 V
Q1 Emitter 7.72 V
Q1 VCE 4.21 V
Q2 Collector 0.00 V
Q2 Base 7.00 V
Q2 Emitter 7.59 V
Q2 VCE 7.59 V
Q3 Collector 7.00 V
Q3 Base 1.35 V
Q3 Emitter 0.71 V
Q3 VCE 6.29 V
When I feed a 500mV Sine signal, the output sounds okay but the output is a
weird sine on the scope. The circuit also quits working after a while if I have
the output scoped.
I thought that the Vce's should be the same for the power transistors. Such a
large difference would account for the scope wave being weird (like 1 sine
wave superimposed on the other), wouldn't it?
John
WBahn
Joined Mar 31, 2012
33,262
The quiescent Vce is set by the bias circuit. If you increase R3 it will lower the operating point. If you want to part things midway, then you need R3 to drop about 5.3 V. With R4 = 100 Ω, there should be about 7.1 mA flowing in it. This should be about what is flowing in R3, so you need it to be about 750 Ω.
elec_dude
Joined Mar 31, 2017
20
I will try changing the resistor to 750 ohms.
Thanks. You folks are such a great help.
catfibres
Joined Oct 17, 2012
7
Hi John, et al.
Since any significant change in the value of R3 will likely alter other aspects of the Bias circuit, it might be easier to throw in a 1K pot - initially set at ~ 750 ohms - and tweak as necessary until bias is balanced. Then measure pot resistance (removed from circuit of course) and replace with nearest fixed value available.
Just my 2 cents...
WBahn
Joined Mar 31, 2012
33,262
That will significantly reduce the power to your 16 ohm load.
Yes, it will. He did so at my suggestion in order to demonstrate that emitter resistors could solve the thermal runaway problem. It was noted that using resistors that size would cause undesirable impacts on performance. The next step would be to find suitable lower values that are an acceptable compromise.
elec_dude
Joined Mar 31, 2017
20
Hi :
One more question. How would I compute the input and the output
impedance of the two stages. Also, how would I compute the gain
of the two stages and the ouput power?
Thanks so much I have learned a lot.
John
sghioto
Joined Dec 31, 2017
8,756
Hi :
John
Uh-oh definitely starting to sound like homework ;)
SG
ColinPatra
Joined Jan 27, 2018
28
Hi
Good for you! But I'm afraid the answer - even a simplified answer - is not easy. The first stage is an 'emitter degenerative amplifier'.The lack of a large capacitor across R4 makes all the difference and the input resistance is roughly R4 * hfe (the current gain - which will be at least 100) so we have 100 * 100 = 10k and this is in parallel with the 15k in parallel with the 100k so about 6k.
The output transistors are working as 'emitter followers'and the output resistance is very low.
You need to understand the h-parameter model really to get to grips with this, or any other ac transistor model. I'm afraid the EDUCATION section here is no help - you need a good textbook and some patience - it takes a bit to get your head round some of the concepts! Good luck though.
Colin
Janis59
Joined Aug 21, 2017
1,894
One cent from me: the 1n4148 looks rather similar to some other diodes like 1n4007 or even Zener diodes with some 2,7...3,6 V(stab). If the voltage on diodes is greater than 2x0,7V You`ve got a trouble. Begin with check up this voltage.
Next cent - impedance is more simple to measure than calculate if there is any loop.
However I didn see it at this case except the 100 Ohm.
Therefore take a 100 Ohms and multiply to average beta..... so the first cascade input impedance will be around 5 kOhm in parallel to R(b-gnd) resistor (I mean 15 k and 100 k both) or anyway around the 4....5 kOhm. Yes, its true that so prost model underestimates the transistor "inside" impact [I mean the r(e)=0,026/i(e)], but is is clear minority value here what may with an ease be neglected.
AnalogKid
Joined Aug 1, 2013
12,282
Not at all correct.
A 1N4148 and a 1N4007 are only vaguely related. A 4148 is a high speed signal diode with low junction capacitance, while the 4007 is a 1 A rectifier diode with large capacitance and very poor response time. It is not recommended for 400 Hz power supplies, and is horrible in audio circuits.
And, neither of those diodes are anything like a zener diode, with very different thermal characteristics.
ak
Audioguru
Joined Dec 20, 2007
11,248
Why is this thread a continuation of another thread with no schematic, no parts list and no link??
The low 12V supply and 16 ohms speaker suggests puny output power (0.75W?) from a very simple circuit.
sghioto
Joined Dec 31, 2017
8,756
Which thread is that? There are a couple of schematics posted with component values.
SG
