Does this circuit make sense?
Scalpel78
Joined Aug 11, 2013
56
Hi, I'm working on a breakout board for the MC33926 motor driver.
One of the output pins, SF (Statusflag), is an active-low which will go low when there is a problem with the driver.
In the datasheet it says that the SF should be tied to VDD via a pull-up resistor.
In addition, I want to add a red LED to indicate when there is a problem (when SF goes low).
Here is a screenshot of that part of the circuit:
This is probably really basic, but do I really need the left pull-up resistor? Will the Led and right resistor also function as a pull-up resistor?
38,624
Possibly not. With only the LED and series resistor, the pullup voltage at SF will likely only be somewhere around 5V minus the LED forward voltage and that may not be sufficient to register as a logic high by the /SF input.
MikeML
5,444
Just use one 470 Ohm or 680 Ohm resistor and a 20mA Indicator LED. The second, parallel resistor is not required. Use a LED with a Vf of 1.8V or so...
ian field
Joined Oct 27, 2012
6,536
Assuming that's an open collector output - its just possible that any slight leakage could produce a faint residual glow in the LED.
The circuit appears to be technically correct, but if there's no residual glow problem, you could save the cost of a resistor.
If its for production - I'd leave the extra resistor in so future tolerance spreads don't cause embarrassment.
MikeML
5,444
I'll bet that residual leakage spec is on Motor Driver data sheet, and I'll bet it is less than 10uA over the entire voltage and temperature range for the part. That will not cause a "faint residual glow".
Ps Here is the data:
ian field
Joined Oct 27, 2012
6,536
Just possible - which is a fair bit short of even likely.
The circuit the OP posted is technically correct - and advisable on a production run.
Scalpel78
Joined Aug 11, 2013
56
Thanks for great replies.
This is just for personal hobby, so I'll try removing the second resistor, and I'll use a red 0603 20mA LED with Vf 1.95V in series with a 680 ohm resistor.
MikeML
5,444
SF is an output...
Lestraveled
Joined May 19, 2014
1,946
Wait a Minute. Not only is SF an output, but the "maximum permissible load current" is 0.5 ma. 500 micro-amps!! You need a buffer to drive that 20 ma. LED.
ian field
Joined Oct 27, 2012
6,536
Just a suggestion - don't use an ultra-efficient LED, some types reach full brightness at only 2mA, even though you'd only get such a faint glow as only visible in darkness, if it was my project that would irritate me.
MikeML
5,444
If you are so anal that you need to worry about the 5uA leakage through the LED with SF_ high, then add the 100K resistor across the LED as shown in the first circuit. I believe the first circuit will work fine as an indicator with or without the 100K. Try it both ways, and let us know.
If you think you need a higher current through the LED, then the second circuit will do it.
MikeML
5,444
Try it on a breadboard or with some clip leads. I'll bet that it is plenty bright enough to determine the state of the logic pin at a glance...
ian field
Joined Oct 27, 2012
6,536
Genius! - that's exactly what the OP's first post said in the first place.
MikeML
5,444
Not quite, his proposed solution was a resistor in parallel with the LED and its current-limiting resistor. Either method would supply the leakage current, although we can make the case that the way I did it, the resistor can be a higher value, so wastes less power.
I went a tried a high-brightness 20mA Red LED at 5V through 100KΩ. That would be about 30uA, six times more than 5uA leakage you are worried about. Not even a detectable glow. However, with ~500uA through it (5V through 6.8K) , it is bright enough.
ian field
Joined Oct 27, 2012
6,536
High brightness and ultra efficient are 2 different types.
