does my power converter have the correct voltages?
blueagent
Joined Jul 13, 2019
my game console voltage: 100v, 47w, 50/60hz
my new power converter: AC 220v, 50w MAX, 50hz
the converter is for 100v game console to be used in local 220v socket here.
i bought the correct power converter right?
ScottWang
Joined Aug 23, 2012
7,505
Here something to be clarify that the power In/Out voltage.
Your game console input voltage is Vin = x Vdc ?
The original power converter is 100v, 47w, 50/60hz, Vout (dc) = ?
Your input voltages of new power converter is AC 220v, 50w MAX, 50hz, Vout (dc) = ?
Edit :
Do you mean that the power converter is the Adapter?
blueagent
Joined Jul 13, 2019
here's an image of the power input/output of the game console and power converter:
https://imgur.com/dE2j0oC
local power grid is "220 volts AC, 50Hz"
Mod Note:
Please upload the file as .jpg to our forum, because it may lose the connection when the site of images is broken.
Audioguru
Joined Dec 20, 2007
11,248
The PlayStation is labelled NTSC which is the old American TV system. It might not work with a European TV or a modern 4k digital TV.
blueagent
Joined Jul 13, 2019
So your game console there is no switch to switching between AC110V/220V ?
How old is that game console ?
nope it doesn't have a switch on the back, it was not meant to be used in my region because it was imported from japan back in the early 2000s.
thanks for the reminder! this problem actually happened back then when i tried to use the playstation 2 on my uncle's old tv which didn't support ntsc, only pal. anyways i remember getting no video output and my uncle was furious because he bought it for me as a present, and he thought he got duped with a broken game console, so he took it back to the game store and i remember seeing him yelled at the guy for scamming him and demanded a refund. yikes....then the guy came out of the shop and took us to another floor of the mall where there is another shop that sells a little TV signal switcher box and it fixed everything. LOL. anways from that day on i always bought sony branded TVs, cause they have ntsc and pal built-in.
Dodgydave
Joined Jun 22, 2012
11,395
It's a NTSC -J standard for the Japan market, if you have a Dual standard TV (Pal Ntsc) then it should play ok, otherwise you need a converter.
