Then futile = V/IResistance is futile...
It was funnier when you posted this twice.Have calculators made us dumber?
Without question simulators have value and purpose. Like calculators, do we rely too much on artificial intelligence and forego using our own?Ok... getting serious now, I think the question is a valid one and deserves some consideration.
In my case, I've been learning electronics front to back. That is, I think I've learned the more advanced stuff first without first bothering to more thoroughly learn the fundamentals. That has made things a bit harder for me in some respects.
But on the other hand, using such a powerful tool as LTspice is has been extremely invaluable. That software has been like having a third wheel in which I can either confirm or refute my hypothesis (mostly refute), and I learn lots of things in the process. And I learn them in a faster, cheaper way.
Creating a circuit simulation also requires imagination and intuition, and it allows to you more easily answer the question of "what if"... I think that, with time and experience, I'm going to rely on simulations less and less, and maybe use them mainly for verification purposes.
Then again, for some of us (especially the old ones), eventually removing the third wheel may prove to be close to impossible.
Definitely that is the point: as in any discipline, a model is an approach, more or less precise, more or less complete.Hello,
A simulator is as good as its models.
When the models do not fit reality, the outcome will be not good.
In my case, sure much much less experienced than you and so many others in the forum, I use it sometimes to see if my basic idea is right or dead wrong. Let us admit that building complex things takes time and not everybody has the means always.Hello,
I do not use simulators.
I build and use an oscilloscope to look at the result. Bertus
Hola César,But on the other hand, using such a powerful tool as LTspice is has been extremely invaluable. That software has been like having a third wheel in which I can either confirm or refute my hypothesis (mostly refute), and I learn lots of things in the process. And I learn them in a faster, cheaper way.
No, but if relied on to the exclusion of all other analysis methods it can prevent someone from becoming smarter.Has simulation made us dumber?
Come on, it is so much easier to sort and put away all the resistors and capacitors when you simulate vs bread boarding. Also, I don't have to worry whether or not I have SMD or through hole parts available when I simulate.I personally can stand them,you cant beat making it on veroboard or pcb and modify it, and play with it using a scope and dvm, to suit your needs, its the only way you will learn.
I'm with you. We put the *old* in old school.I don't simulate, except between my ears. Then I build.
