Do 6v 2500mAh-1000mAh Lithium Batteries exist?
JefferyJames
Joined May 3, 2020
8
I want a lithium battery due to the constant nominal voltage during its discharge.
JefferyJames
Joined May 3, 2020
8
I suspect so. Have you looked?
Battery packs for power tools might be just the thing you need.
I found one though its restricted to 1000mA continuous discharge current.
Say I have my circuit (as you saw in my last post) and the total current of each part to work is 4635mA, will be continuous discharge current have to be higher than this?
Papabravo
Joined Feb 24, 2006
22,111
Audioguru again
Joined Oct 21, 2019
6,826
A normal Lithium rechargeable cell is 4.2V when fully charged so two in series make 8.4V which is much higher than the 6V that you want. There are newer Lithium cells, LiFE04 that are about 3.6V when fully charged, then two in series make 7.2V that might be suitable for a 6V powered product. I do not know if a 2-cells pack of LiFE04 cells and charger are available.
KeithWalker
Joined Jul 10, 2017
3,617
2500mAh lithium-ion do exist, but not 6V. They definitely do NOT have constant voltage during discharge. Two cells in series would be charged up to 4.2 volts and would be cut off when the voltage dropped to 3.2 volts.
I use 2500mAH two-cell packs to fly some of my smaller RC planes, discharging them at 15 to 20amps to get 7 to 10 minute flights.
Regards,
Keith
