I’m impressed with the amount of work that you have put into this project, admitting that you are a novice – having managed to construct a transformer which in principle may do what you want.
To assist, I have attached an outline of a circuit design idea that might work – charging a lithium battery at over 100A. Typically a lithium battery will be fully charged at 4.2V, but you need to check the specification of your battery.
The circuit design (showing the transformer secondary winding) uses a thyristor to control the battery charge current. A thyristor can be considered as a diode that is switched on when an appropriate voltage is applied to the gate.
Not shown in the circuit diagram is the detailed control circuitry providing the gate switch voltage. With the battery voltage less than the fully charged voltage and the charge current less than the maximum, the circuit will switch the thyristor on; should either the battery charge voltage or current exceed the maximum levels the circuit will switch off the thyristor.
A further requirement of the circuit (not shown) is that it must be fault tolerant such that should any component fail, the battery will not be subject to charge/discharge outside its specification.
If your design works using a diode, then you need to replace the diode with a thyristor, with control circuitry. Controlling the gate turn on signal as required, could be achieved through a fairly simple circuit – but the add-on protection circuit might be more complicated.
