I have a vague plan to make some heated clothing and I wanted to check whether I'm approaching it the right way. The heated clothing you can buy is generally designed to be worn as an outer layer but I think that's a pretty inefficient route compared to heating an inner layer and trapping the generated heat.
For the heating elements I want to use carbon fiber cloth cut into strips. You can buy carbon fiber fabric in a narrow format but it's more expensive than buying 36 cm x 91 cm and cutting it into strips. Cutting my own strips will also allow me to control my resistance per meter. I will use a sewing machine to sew these carbon fiber strips onto the outside of some cheap long-sleeve t-shirts and "long underwear" aka long johns.
I would like to use two of these power bank boxes which accepts four 18650 batteries and produces up to 2 A at 5 V. This would only be 10 W per clothing item but alternative methods of obtaining power are more expensive and/or more effort. There's a 3 A box but it's much more bulky. Maybe I could tie together the positive and negatives of the insides of two of the 2 A ones to get 4 A (I'd want them to both cut out about the same time).
I will attach the power bank boxes to a belt and find a way to sew some USB cables securely onto the clothing (technique called couching, I suppose). I guess I'll put them in a pillowcase in order to wash them.
