Dividing 0 to 100% exponetially for dimming light
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. I need to dim a light 0 to 100% depending upon user input 0 to 100.
Have a driver to which when I pass value 0 to 100% by microcontroller it dims the led accordingly.
2. I was reading below image from this datasheet: https://www.ti.com/lit/pdf/slvaef3
3.Page 6, says "Human perception of brightness is not linear with luminance of the LEDs and is more sensitive at low
luminance, which is approximated to a logarithmic curve. So if the linear dimming control method is used,
the final perceived brightness is not linear in human perception. That is why exponential dimming is used."
4. Now have to divide 0 to 100% exponetially? How do I divide the number 0 to 100% exponentially when user input comes 0 to 100?
Tonyr1084
Joined Sep 24, 2015
9,744
Not only is light perception non-linear, so is audio. They sell "Linear Taper" pots and "Audio Taper" pots. The audio taper pot is exponential or inverse of exponential, depending on how you hook it up.
wayneh
Joined Sep 9, 2010
18,156
The equation for an exponential curve is:
Brightness y = C•((exp^a•x) - 1)​
where C and a are constants and x is duty cycle.
Since brightness y is zero at x=0 and 100 at x=100, a is forced into being a function of C:
a = ln((100+C/C))/100.​
Changing the value of C gives a family of curves with different degrees of curvature, all passing through zero and 100. C=1 is highly curved while C=100 is nearly linear.
The inverse function gives x required for a given brightness.
x = 100 • ln(y/C + 1) ÷ ln(100/C + 1)​
28,227
We do not have any hint as to what type of light it is, and different kinds have different relations between drive and brightness.
And why does the relationship need to be uniform? In reality it is very seldom uniform.
Ian0
Joined Aug 7, 2020
13,270
According to the relevant standard BS EN 62386-102, the brightness should vary logarithmically over 3 orders of magnitude, i.e. from 0.1% to 100%, so you need at least 10 bit resolution for the PWM.
wayneh
Joined Sep 9, 2010
18,156
