I recently put together a small amp from my so called junk box of parts and the amp is up and running with no DC offset, overheating or other problems except bad distortion.. I used an unregulated power supply board fed with 24 volts on both rails but after measuring the voltages on the Vcc and Vee pins of both boards it is higher then the recommended 35 volts max. My readings show 38.7 on one channel and 38.9 on the other. This is a bit over the maximum suggested by the board manufacturer and possibly the issue for the distortion.. Is there a way to reduce the output safely and reliably down to say 30 volts or even 25 without too much trouble.?. I could change the transformer to a lower voltage one but this is an added expense. I also measured the ac coming of the transformer and it is higher then the 48 volts CT then it states.. Any suggestions would be welcome.. I did read somewhere that you can use a zener diode to reduce the output but this does bot sound reliable or safe in my view Thanks for reading Cheers Wayne
