Hey all,
Lately I've been experimenting with control voltages (CV) that will turn on or allow audio signals to pass into either a filter, graphic equalizer, distortion, etc. The attached circuit is a simple glide. It has a buffer on the input and output, and between the two buffers is a potentiometer which sets the the time it takes for the capacitor to charge, sustain, and discharge. From the last buffer, the CV is feed into a resistor that is connected to a transistor. As the voltage ramps up the transistor slowly turns on and off based on the time factor of the potentiometer and capacitor. When the transistor turns on it allows the audio signal to flow through, which is represented in this circuit as 100 mV at 600 Hz.
So the problem that I've run into is that at the beginning of the turn on and at the end of the turn off cycle, I get distortion in the audio signal. I do not get distortion when the voltage surpasses a certain voltage. I've tried lowering the audio voltage signal and high pass filters.
How do I remove this distortion?
Please note that the transistor that is represented in this circuit diagram is not the one I am using. I am using the 2N3904.
Thanks so much.
The Damage Dealing Meat Shield
Thanks so much.
